quest ram mount users
  • Thread starter Thread starter ericthebrave
ericthebrave
Whats the vibration like with the long arm (B-149z) and the quest mounted above the clocks with the ram kit? (ie the popular mounting method as shown in lots of pics on here) I'm going to get th Qpac unit as well which will add a little bit more weight on the end of the arm.
If the vibration is an issue, i'll go for a shorter arm, and no i dont intend to be staring at the GPS all the time lol but if its vibrating and i'm only giving it a quick glance then it'll be harder to read!
I doubt vibration will be an issue. I use the short arm myself but I spoke to the Ram guy about it at the time and he indicated it shouldn't be a problem. Just make sure you use the correct shim etc and you should be fine.
