Nick Marshall Well-known member UKGSer Subscriber Joined Aug 19, 2002 Messages 2,451 Reaction score 447 Location Shropshire Nov 18, 2007 #1 before i order 4 of these, does anyone know if the R&G crash protector will fit on the shaft on a R1200GS. I know it fits the K1200R which looks about the same, only its the other way around.
terayon Registered user Joined Nov 5, 2006 Messages 905 Reaction score 0 Location Luton, Bedfordshire Nov 18, 2007 #2 Yes it will, nippy norman sells them for GS
dlevett Registered user Joined Oct 11, 2006 Messages 345 Reaction score 0 Location Jo'burg South Africa/York UK Nov 18, 2007 #3 terayon said: Yes it will, nippy norman sells them for GS Click to expand... I have to admit to being a bit of a ludite - I couldn't find them on Nippy's site
terayon Registered user Joined Nov 5, 2006 Messages 905 Reaction score 0 Location Luton, Bedfordshire Nov 18, 2007 #4 sorry, was getting nippy's mixed with Bike bits http://www.bmwbikebits.co.uk/products/product-64-RG_Racing-Shaft_Protector.htm
Ali-bear Well-known member UKGSer Subscriber Joined Sep 7, 2007 Messages 940 Reaction score 57 Location Wotton under edge Nov 18, 2007 #5 I was thinking about getting one of those. Does the original plastic pivot cover just pop out, with a bit of screwdriver-based persuasion?
Stoney Registered user Joined May 8, 2003 Messages 882 Reaction score 0 Location Leeds Nov 18, 2007 #6 Fits in minutes - works a treat. They also do ones for the forks.
Nick Marshall Well-known member UKGSer Subscriber Joined Aug 19, 2002 Messages 2,451 Reaction score 447 Location Shropshire Nov 19, 2007 #7 thanks lads can get my bulk order in now. unless they all want fork ones as well!
shedracer Well-known member UKGSer Subscriber Joined Dec 7, 2003 Messages 1,890 Reaction score 499 Location Dorset. Nov 19, 2007 #8 Just the rear shaft drive one for John, bro and me. Cheers Nick.
Nick Marshall Well-known member UKGSer Subscriber Joined Aug 19, 2002 Messages 2,451 Reaction score 447 Location Shropshire Nov 19, 2007 #9 cheers shedracer said: Just the rear shaft drive one for John, bro and me. Cheers Nick. Click to expand... will get on the case asap.
Ali-bear Well-known member UKGSer Subscriber Joined Sep 7, 2007 Messages 940 Reaction score 57 Location Wotton under edge Feb 9, 2008 #10 Well I finally got round to fitting mine, but I can't seem to get the original plastic cover out of there without doing it some damage. Any advice?
Geeza Registered user Joined Sep 6, 2004 Messages 238 Reaction score 0 Location Kent Feb 9, 2008 #11 Protecting Mi Shaft Yes....it does fit. And Yes....you will probably damage the shaft when trying to get the plastic cover off. Suggest you disturb the cover from the bottom. At least if you do chip the paintwork it will be out of view....hammerite smooth does the trick. Also might be worth spraying with ACF50/WD40 while you have the cover off Attachments R&G Bung.jpg 34.3 KB · Views: 158
Ali-bear Well-known member UKGSer Subscriber Joined Sep 7, 2007 Messages 940 Reaction score 57 Location Wotton under edge Feb 9, 2008 #12 Yes I just did it in fact. Used an old plastic ruler and screwdriver combo. It is held in place by the centre being a tight fit in the hole. I found that meths and some gentle rubbing removes the R&G contact details from the bung nicely.
