bernardofeio
Helloo
Is it possible to convert a “normal” R100GS gearbox to kick-start?
bernardo feio
bernardo feio
It can be done but really isn't worth the expense. It's much easier and cheaper to track down a second hand kick start gearbox. If you ever try to kickstart one you will wonder why you ever bothered![]()
I thing I get your point….
Old land rovers also have a hand crank… but I’m still to find someone that already managed to start a 23:1 diesel with it!
If you get an empty battery while off roading is there any trick to start the beast?
Interesting what he's doing with the ignition switch in between kick attempts - is that part of the "process" that i've been missing?
