R100 P/D no sparks - help needed!
delboy
Dundee, Scotland
Got hold of a nice 1995 R100P/D last year and spent the last few months tidying it up ready for this summer. Since I have had it, it always started on one cylinder only but after only a few seconds the other one would kick in and it would run on both thereafter. Took it out last week and got it MOT'd doing a round trip of about 30 miles during which time it ran beautifully. Even spent some time balancing the carbs on my return and it was idling perfectly throughout.
Decided today to investigate the cold starting issue only to find that it would not start at all. No sign of a spark at all at either plug so panic has set in!!
My other airhead is an much older points model so I am not familiar with the electronic ignition models. Any thoughts/advice/help etc would be much appreciated.
rest a plug on the cylinder head with the HT lead attached and then flick the kill switch on and off several times. If it sparks then it could be your bean can hall sensor.
You could always pick up a cheap spare ignition module. Second hand one of these would do http://www.ebay.co.uk/itm/Porsche-9...623?pt=LH_DefaultDomain_3&hash=item1e9bf13aef
Or look for Lucas DAB400 or intermotor 15000 or any of the units on this list if you fancy grubbing about in a scrap yard or searching ebay
BOSCH 0 227 022 008
BOSCH 0 227 100 100
BOSCH 0 227 100 101
BOSCH 0 227 100 103
BOSCH 0 227 100 104
BOSCH 0 227 100 113
BOSCH 0 227 100 116
BOSCH 0 227 100 118
BOSCH 0 227 100 136
BOSCH 0 227 100 137
BOSCH 0 227 100 138
BOSCH 0 227 100 139
BOSCH 0 227 118 307
BOSCH 0 227 200 005
BOSCH 1 227 010 001
BOSCH 1 227 022 008
GM 120 8033
GM 120 8241
GM 120 8246
GM 1208 033
GM 1208 241
GM 1208 246
BMW 1214 1244 089
BMW 1214 1244 191
BMW 1214 1244 477
BMW 1214 1244 481
HUCO 13 8002
HUCO 13 8083
VOLVO 1317 809
VOLVO 1389 939
INTERMOTOR 15000
LADA 2108 373 4910 10
VAG 211 905 351 A
VAG 211 905 351 B
VAG 211 905 351 C
VAG 211 905 351 D
SCANIA 257 3826
SIEMENS 2576 12 70 01
TELEFUNKEN 333 231
TELEFUNKEN 335 622
TELEFUNKEN 338 738
HELLA 5DA 006 623 011
SIEMENS 5WK 6101
SIEMENS 5WK 6105
MAGNETI MARELLI 648 330 32
FAIRCHILD 8115 FD2
SAAB 857 3826
BOSCH 9 222 067 023
GM 900 061 45
GM 900 064 99
GM 900 081 45
GM 901 146 76
GM 901 401 87
SAAB 939 0220
MAGNETI MARELLI BKL 3C
TRANSPO BM300
LUCAS DAB400
FISTER HW601
MOBILETRON IG-H004H
UNIPOINT IM-BH7
LIGHTEN POINT M1
AEG S339 109
FAIRCHILD SH 4246
FAIRCHILD SH 4279
FAIRCHILD SH 433
SUPRA SIM1
AEG TZ1 338 736
CI XEI 4
BERU ZM 002
He's like the rainman of bikes. Incredible.Brilliant
I have a friend whose an avid gambler on the horses. came over to visit me for holidays once and his suitcase was full of form books. I can imagine Bob having such a suitcase:D
I'm just recycling stuff Thats Been posted over the past 12 years or so. Nothing special about it.
richC posted the original list when he worked for intermotor
Yeah, but you memorised it and posted it here after all this time.
You're too modest.
Many thanks for your help so far. I will check the spark plugs/kill switch as decribed and get back to you.
Have tried flicking the kill switch as suggested but not a sign of a spark. When I find time I will check the coil which I undestand is prone to failure.
Derek
