My mono had a bit play when I bought it, 130,000 km back, and it didnt change much until recently.
But it is the type with a needle roller on the drive side, and up to 2 thou clearance at the large bearing is permissible, which translates into about 20 thou at the rim.
Not too hard to work on - there is a removable cap on the drive side which lets you measure things and get the bearing in the right place, and I made up a spacer the same size as the bearing so I could do a trail build and order the spacers and shims all on the one order.
The Para's would be much more difficult, if you intend to do the job properly and set tooth wipe and backlash as well as just replacing the large bearing.
Problem with the Para is that there is a taper roller one side, and the large C3 deep groove ball the other, with 2 thou preload, and if you get a bit play it could be either, or both, bearings, and both are a job for someone with expensive equipment.
Replacing just the large bearing, and seal, without reshimming is a job any bodger could do at the side of the road, but doing it correctly requires the bearing housing to be heated to 80C to remove the bearing , and the crown wheel really needs to go in the freezer to get the bearing over it.
So only those who carry the fridge and cooker with them shouuld try at the side of the road - maybe that is what they carry in the huge tin boxes you see on the back of most GS''s!
