turnipbmw Registered user Joined Apr 28, 2006 Messages 4,120 Reaction score 1 Location Aldbury Sep 14, 2012 #1 Anyone point me in the direction of somewhere that lists the engine differences of all R1100 models ? Am suprised there are any - why would you do that
Steptoe Him/Bloke/Fella. UKGSer Subscriber Joined Oct 12, 2003 Messages 73,748 Reaction score 22,872 Location S/W London. Sep 14, 2012 #2 Early 1100GS engines have bigger valves.
nick.ct Well-known member UKGSer Subscriber Joined Sep 28, 2005 Messages 3,326 Reaction score 184 Location Ashbourne, Derbyshire Sep 14, 2012 #3 R1100S 98HP, 97Nm R1100R/GS 80HP, 97Nm Be interested to know how many of the early R1100 had the big valves and which models
turnipbmw Registered user Joined Apr 28, 2006 Messages 4,120 Reaction score 1 Location Aldbury Sep 14, 2012 #4 I only ask because Motoworks say they need chassis number before they will sell you a second hand engine. Apparently there are many different types I would have assumed that any R1100 engine would fit any other R1100 even an 'S' I stripped an 'S' engine and it seemed identical to an 'R' engine I had in bits. here is an interesting engine rebuild thread I found today
Pekkavee Registered user Joined Oct 10, 2007 Messages 576 Reaction score 8 Location Finland Sep 15, 2012 #5 Example BMW R1100R engine is the same as these. Same engine If you have an R1100R these fit for you. No other. Have a look in BMW Max Fiche to find your engine. Search with a part number which is the same as you need Pekka
uncle dick Well-known member UKGSer Subscriber Joined Oct 4, 2009 Messages 1,553 Reaction score 3 Location Devon, England Sep 15, 2012 #6 Compression ratio, valve sizes, valve timing, con-rod material, plus all the external stuff like ecu's, injectors, throttle bodies, exhausts etc etc. Use the links section on here to find various useful publications Quite a bit in my Clymer manual as well - not sure if there are EU/US variations on the internals. You can find all this on RealOEM. When you've done that, a handy reference table as a 'sticky' would be just great Dick
