brucewayne
Well,
I think I've found the source of a few elec probs I've been experiencing lately incl. RID not working, unreliable battery and main beam weak.
Inside one of the grey rubber "tell tale" bulb holders for main beam (on the dash panel) the electrodes had been touching, causing a short and burnt/melted wires.
The melted wiring seems to be confined to the 2 inches nearest to the bulb and not down the rest of the front loom. Until that is, it gets to the connector (under tank)...
just after the connector the following on brown/white main beam wire also got melted, but again only the first couple of inches. Following it down the loom it doesn't appear to have melted anywhere else, for a good visible 8-9 inches.
Thought I cannot tell without stripping out the loom completely.
Really don't want to replace the whole loom for obvious reasons.
The fusebox and wiring underneath seems to be completely clear of any damage too.
QUESTION - Is it common for short circuits like this to just cause damage in just part of the wiring? leaving a repairable section? or does it always cock the whole loom?
As you can tell I'm very keen to not have the whole loom out and replace.
Thanks all
Thanks all
