r1100gs vs 1150gs diy maintenance
bart2181
birmingham england
hiya lads.any difference between the two in terms of diy maintenance?i know the 1100 is fairly straight forward for your average home diyer but how about the 1150.cheers
I guess the only real difference is the fact that the 1150 has a hydraulic clutch. Which is better from a maintenance point of view could be argued either way I guess although I will say that on the 1100 the cast ally lever arm down by the gearbox can crack and fail. It happened to mine a year or so ago, but there is a steel upgraded part available.
I agree with Mark, the clutch is a double edged sword for maintenance.
The other issue, from a DIY standpoint, is the servo-assisted brakes for the 2003-2006 bikes. You really need to bleed the ABS pump once a year and that's not as simple as the pump on the 1100 and earlier 1150.
The rest is easy-peasy.
