R1100S/R1150GS heads identical?
monkeyboy
Hants, England
Just the head, the cams are different I would guess but are the physical heads the same? I've got a buggered R1150 head but good valve gear/cam - can I put an R1100S head on with the 1150 top end gear?
Exhaust fixings are different. 1100 has three studs, 1150 2 studs. Dont know if anything else is different though.
Single spark ones are I believe interchangeable, 1100S has 2 stud exhaust fixing
Part # 11121342199/200, LHS/RHS up to 12/2002
The R1100GS has 3, the R1100S has 2 just like the 1150. I've got an R1100S in the garage:thumb The head I want to fit on my GS came off a crashed 1100S.
I took the head off - tried (and failed) to drill out the exhaust studs that were virtually corroded through, snapped a drill bit in one, went and got it spark eroded but the drill bit seems to have conducted the heat and melted out a hole where the head mounting bolts go through:rolleyes: All my own fault. I'll cut out stage A and go straight to the spark erosion on the other head!
