Right, I am back to this. No progress made and I would welcome any advise.
Just to recap, I removed the gearbox with the final drive to carry out maintenance on the splines. When I put everything back together, I found the bike would start only when (whilst in neutral gear) I pulled the clutch lever in. Otherwise the bike worked fine during a couple of test runs.
The neutral light (green light on the display) doesn't come on either. After further fiddling, now the starter motor does not fire up/ turn over.
I have had the starter motor examined by a local engineer and it is working ok.
I suspect my fault may be with the side stand switch.
Can anyone tell me if a faulty side stand switch would stop the neutral light coming on? Or should I look at anything else. Starter relay perhaps?
Plug connectors and wiring appear ok...
