R1150GS running issue
g00ner
Quite a long way from the top
2004 R1150GSA - cat removed, Sebring end can
Pulls cleanly till 4500 revs, then a massive flat spot between 4500 - 5000. Pulls cleanly after 5000. All gears, regular as clockwork, big hole in power 4500 - 5000
Coil Sticks? Seems odd it’s just that 500 rpm window :nenau
Had a kind offer from Phil (fatnfast) to check the throttle body balance and valve clearances but if I can save him the hassle...
have you access to a spare TPS off a known good machine??
and i have come across a few incidents of Lamda probes causing issues thankfully it's a default map in the ECU that the lamda influences and disconnecting the Lamda just resorts to default fueling
So try a disconnect of the Lamda and then if that doesn;t work try replacing the TPS
"But" it has to be off a known good bike or you are still "guessing"
Running issues
Hi, contact gs John on here he supplied me with a stage 10 chip for my 1150 gsa my bike has more torque more power and no flat spots
This is what tends to happen when you decide to change the exhaust system that a manufacturer has spent a lot of time and money developing so there were no flat spots... “ yeh, but it sounds great don’t it mate” :D
I did wonder if it could be that, hence my wanted ad. Only collected the bike yesterday so trying to sus it out :thumb2
Just fitted my stage 10 today, plus added 1200 injectors from Tillman.
The Black one is the 1200, Grey one the original one. Don’t ask why I’ve swapped the injectors, I came across a post on here about someone else doing it, and I’m very, very gullible :nenau so probably another £120 squandered :blast
When the “Male” QD Connector arrived from Motoworks ( don’t ask :blast) I’ll give an update. :rob
I do have a mint collector box for an 1150 and replied to your pm Gooner
In one
People piss about with a bike weighing 250 kgs in the hope of making it go faster
Fit decent suspension and ride the torque
Cheers, will get back to you
In one
You spent last Summer hunting for a Remus :D
Went through this over 15 years ago:-
R1150GS with standard cat and can ..........quiet with the occasional pop and bang and no running issues
R1150GS with Remus decat and Remus race can ........... yes it went a little bit better at the top end was excessively noisy and popped and banged all of the time but lost midrange
R1150GS with standard cat and Remus race can ...... noisier than standard and went the same as standard
R1150GS with remus decat and standard exhaust ......... sounded quieter than the standard cat/Remus can option but slightly louder than standard, not popping and banging all the time, a decent weight saving and no running issues .
Later tried it with the Remus decat and a Remus road can but went back to the decat and standard silencer
J’me sourcing a cat and standard can. Won’t fit them till I know everything else is ok (with FanFast’s help). I replaced the cat in my last GS rather than the Remus Y-piece fitted as I preferrred the silent approach, can see where this is heading
It is odd how the ‘hole’ in the mid range (and it is a whopping great chasm, not a ‘bit down on power’) occurs at exactly 4500 rpm and clears at 5000. You’d think it was electronic with that consistency
Re-catted and 90% of the issues are gone. You can still feel some 'hesitation' at the same revs but I'll let it run a couple of tankfuls before wondering whether to fit an original end can too. I'm hoping it'll improve the economy as I only got 220 miles from a full tank, probably because you had to keep the revs above 5K to make it go - and it went very well when given the revs
Now it's nice and smooth and quite(r) just how I like it. The Urban is for noisy shenanigans :thumb2
EDIT: None of the above would have been possible without FatnFast's endless patience and good company...valve clearances set, throttle bodies balanced, 12V supply rewired, Cat refitted, fuelling maps changed etc etc.
Top Lad Phil :beerjug: :thumb2:bow:clap
Standard cat fitted with a "stubby" exhaust. Runs perfectly well, no noisier than standard, with the bonus of same sized luggage on each side.
Aww shucks ya to kind :-) ........and I've now moved and I'm not giving you my new address.....;-)
