Buzz Lightyear
Two things I have recently done that may have caused this:
I sprayed WD40 in the horn switch as the horn was no longer working. The horn did not work and I thought no more on this. Perhaps this was enough to cause the issue?
I removed the fuel tank to take off a set of Denali driving lights from my adventure, put the tank back on and connected up the block connector on the RHD side of the tank but the indicators and headlights are no longer working. The rear tail and brake lights work, the font side light is on. I have removed the tank in the past and had no issues then. Any ideas?
