Aidjay
Both my power sockets don't work. They haven't worked for years, but I'm looking to fix them now in preparation for a big trip.
1st socket on the top left side had what appears to be some sort of copper corrision on one plug - see pic. I used WD40 to clean most of it out. I read elswhere that a bit of vinegar should clear this away, any suggestions on how to prevent this from re-occuring? I haven't tested it yet, as I don't have the means.
Considering this as it looks useful, not just for the test: http://www.nippynormans.com/LED-EMERGENCY-LIGHT-with-DIN-plug-fitted/productinfo/BAS-BA40/
The 2nd socket near the starter motor is in worse shape. I noticed that the red wire was supposed to be part of a connector, similar to the brown wire circled and arrowed in the pic.
Am I ok to simply splice the two red wires together, or do they absolutely need to be combined inside the connector? The reason I ask is there as absolutely no slack on the connector which makes it very tricky.
Any help is highly appreciated!
