The bike's now done over 300K and developed something between "klacking" or "ticking" noise when warm and on idle after a Central-Asia and Mongolia trip. Coming from the left cylinder. It comes and goes, but mostly there on idle only, dissapears instantly once giving it a rev. It's getting annoying and I've ruled out some things:
It's not worn throttle bodies - done a complete TB rebuild recently with new shafts plus touching the shaft doesn't dampen the noise as with "ticker" noise issues on most R11xx bikes.
It's probably not the camchain tension - installed the updated hydraulic preloader recently
It's not the valves or rocker arm clearances since they are well within spec.
Could a worn camchain plastic guide do this? But with this there should be a noise on higher revs too, right?
Anything else I should look for?
Many thanks in advance!
Margus
Margus
Now I just readjusted them to the minimum recommended 0.05 mm while I was there.
