An interesting thread.
I own a servo abs equipped 2003 1150GS and twice in exceptional circumstances the ABS has cut in unexpectedly under hard braking on low friction surfaces. Did it save my skin? Maybe, I understand cadence braking and have used it in cars and on bikes without ABS. When it's slippery though the ABS will likely beat even a good and well practised human which I don't incidentally claim to be.
I have however experienced ABS failure on a loan 1200 servo ABS bike which resulted in a locked front wheel on a wet road. I was lucky and released the brake lever quickly enough to avoid the fall and retain control so ABS is not always essential.
It is also worth considering that what ABS does is release your brakes when the wheel slides. If the surface on which you are riding has a low enough coefficient of friction (grip) then you effectively have no brakes at all. Try riding your ABS bike on ice and see what I mean.
In 45,000 miles I have had
no problems of any kind with any of the clever (?) bits. However, they are mechanical and will fail eventually.
I for one appreciate people like Nemezis bringing failures to our attention. I also think that as English is not his first language there can be a "loss in translation" (LIT). When he refers to a perfect non ABS system I take that to mean a traditional hydraulic bike braking system in
good condition and not suggesting that such a system is perfect. On that basis it cannot develop the Servo/ABS faults as the components are simply not there and hence there are fewer faults that can develop. His statement that people who buy ABS bikes deserve only 25% braking is again a bit of a LIT and I would guess that he means that if you make the purchase aware of the known faults then you shouldn't be surprised if it happens to yours.
Next, if a circuit fails on a traditional system you still have one circuit so are you really any worse off than having 25% of the clever system. Probably not.
Lastly it is most regretable that such a thread deteriorates to mud slinging and personal insults. No benefit is dervied from this by anyone.
Of course the above is purely my view and interpretation of what has preceded it. I may of course be completely and utterly wrong
