masherbike
I have a GS 1200 which is just over 2 years old with 14000 mile on the clock. Ever since the last service at 12000 miles it has a smell of burnt engine oil when I stop. There is no sign of an oil leak, I have checked thoroughly and even taken back to the dealer the week before the warranty ran out. They said they couldn't smell it and there is no leak. The smell is definitely there, my 12 year old Fireblade doesn't smell.
I did notice that the dealer filled the oil level up to or above the upper limit. When I took it back to check the smell they topped it up once more above the upper level.
I have checked the air filter which is dry. Engine is running perfectly. I have read other posts and it seems I am not alone, but I have yet to find a definitive answer.
I did have an oil leak in the first year which was very slight and didn't cause a smell. It was the engine output shaft seal which was fixed under warranty, a new clutch was fitted.
I have read about leaky cam chain adjusters, mines not leaking.
Does anyone else have this issue? Please let me know your experiences.
