R1200GSA Lowering
ste007
manchester
Hi not sure where to post this question? Looking for advise on the best option to lower my 2009 GSA other than a lower seat conversion. Any advise would be much appreciated
Regards Steve
Denz0 on here(Lukas) at TTech suspension serviced and lowered my GS shocks 30mm. Loads of recommendation on the forum for his work.
Lowering a 2009 is fairly easy
30mm lower shocks front and rear - Denzo , Wilburs etc - £250 - £400
You will also need a lower centre stand - 30mm cut out and re welded of the uprights if pretty straightforward
The side stand however needs a different approach,
you can purchase a lowered side stand from the mother ship, or you can cut out 30mm from the side stand and re weld it,
however you need to cut the 30mm out in a certain place so you keep the lean angle relative
Add a factory low seat, and your balls to flat footing it
I have a set of Hyperpro lowering springs in my garage from my old 2009 GSA gathering dust, PM me if you want further info and I'll dig them out.
You just need GS shocks and stands. And maybe lower seat if you need.
