Have my bike plugged into Optimate Charger all the time for triggle management as its only riding maybe every 2 weeks. Had it out 4 times this week though so had a good run over 200km.
Took it out today to pop down the shops and the missus popped inside I turned it off whilst sitting reading the phone.
Tried to start it when she came out, it flashed up with brake light fault across screen contact service centre. Then tried again and it showed tilt sensor activated unable to start. Bear in mind I had been sitting on it stand up with 2 feet planted the entire time.
Battery showed 12.2 V, and screen wasn't fading like a low battery but the started would tick over twice then fade off. This went on and on around 4 power of on and ons and trying start button.
Moved the bike to another spot by pushing it as I was just on roadside with a bit of traffic. Again same on of and 2 start attempts then fade off.
Send herself off for tea and coffee as she had a angered expression. And I gave it two more tries and it decided to kick in. Straight up and running fine.
Only thing I done was touch the cables going into the top of the cylinder heads to see if they were loose.
Anyone have this happen ? I seen some posts in the states of similar issues.
