Oh boy now you are going to give me anxiety!!Mine already had the 16ah Yuasa battery, with 240cca
I must admit this is the first post I have seen mentioning they have the same issue with this battery so interesting to know.
Likewise mine has the bigger Motobatt unit, still didn't stop mine from having the issues.Mine already had the 16ah Yuasa battery, with 240cca
The first time it happened to me I was a 5 minute walk from my house. I had nipped into the local Tesco.Does anybody know how the decompressor works ?
I wonder if it is a hydraulic piston using engine oil pressure to hold the decompressor off with the engine running, making decompression its default status ready for a cold start........
Ergo if it doesn't bleed down on stopping for five minutes, the engine could be trying to crank under full compression?
Give it five minutes to do its thing and decompress the cylinders and the engine starts?
Just a thought.
Get it on an Optimate!I've been having simialr issues, replaced the battery with the Yuasa linked earlier in this thread in the hopes of resolving but its still occuring
Bought my 1250 GSA recently and on occasssion in stop start traffic I have stalled it, I go to restart and it attempts to turn over, fails, and brings up a Traction Control error on the dash, I go to start again and it tries momentarily again but wont start. It seems if I swith the iginition off, wait 10 ish seconds, back on again and start again its fine. But deadly embarrassing.
Differnet circumstances but the same issue, got the bike out and started it on the drive, realised I've forgotten something so tunred it off, come back ~30 seconds later and it wont start. TC error and all. Wait a while longer and its fine.
Its due in for a service in May so i will raise it with the dealer then.
Did you get the higher capacity battery as there are two versions??I've been having simialr issues, replaced the battery with the Yuasa linked earlier in this thread in the hopes of resolving but its still occuring
Yeah defo sounds like you have other issues going off hereYeah I got the higher capacity Yuasa. Its on an Oxford trickle charger in the garage when not in use so voltage isnt the issue. It's the same problem on two batteries so I feel its unlikely to be the culprit.
