R1250gs bar riser issues
motor_mad_man
London, England
Good day to you all.
I've fitted a set of wunderlich up and back bar risers to my wife's new r1250gs. Which was fitted to my r1250gsa, without any issues.
Now on fitting them to the r1250gs the clutch pipe and wiring are very tort on full lock.
The bar is set to 10 degrees. Which is what mine was set too
The only difference in the bikes is that the gs is a low chassis one
Anyone else had the same issue, or know a fix.
Yes I had the same problem. You will have a bit of wiggle room on the clutch lever position. You can move it inboard a few mm, there is enough flex in the plastic hand guard. You can also alter lever angle. Finally you can alter the tilt of the bars. All small changes but did the job for me. Failing that you can drop the forks and route the cable to the outside of fork.
I have now gone for ROX pivot risers, which give you even more issues and you then MUST drop the forks
I put Helibars on my 1200 just to get narrower bars to get through my back gate.
I had to drop the forks which honestly is a 5 minute job.
