Riser issues
  • Thread starter Thread starter Capsize
Capsize
Have just received risers from NN and tried to fit them.
Luckily I noticed that when one bolt was lined up and in the thread the other was at a slight angle. This only ruined a couple of threads but I spent a nervous 20 mins getting the bolt to re-cut the thread again without the risers in place.
Sighting down through the risers I can see that the holes are about 0.5mm out of line with the thread ( too short).
Has anyone else had this problem with the NN risers, or, is there a trick to fitting them.
Should I drill the risers to expand the hole by 0.5mm, or, should I just return them to NN.
Caps.................
caps I fitted some to mine several months back and they
fitted straight on, give Norm a ring he is very helpfull :thumb
fitted in seconds
mine fitted in seconds, pefect risers with setback. However, i'm taking them off, done about 1200 miles with them. They do obstruct right hand lock a tad and i'm not sure they are quite in the right position for me :beer:
