R1300RS Handguards
Katie
Member
Gloucestershire
I had originally fitted an old pair of cheap and very nasty handguards to see how they worked. They fitted fine but didn't have great coverage and my hands were still getting very cold. So, thought I'd test the Barkbuster Storm handguards, the ones with the bar end fixing.
These come with the option of an M8 or M6 bolt. As the OEM bolt is M10 a thread reducer was needed (M10 x 1.5 external to M8 x 1.25 internal - from Ebay).
The Storm handguards retain the BMW bar end weights which have a lovely M10 sized hole through them so I used an M10 rod, internally threaded to M8 (see pic, sourced from Ali express a couple of years for another project). The ones I have are 28mm long so chopped in half worked perfectly :)
The countersunk M8 bolt supplied was a bit short so I swapped for a longer hex head (will change these at some point, purely for aesthetics)
My initial try out suggested not much of a win in terms of upper hand coverage as they clashed with the mirrors on full lock. A bit of playing around made me realise that the steering lock still engages without pushing the bars right to the stop and that gave me a lot more room to manoeuvre.
So, threadlock applied all round and everything left to set. Now just need to test on the road :)
Pics shown with steering lock engaged
Just to finish this, end bolts were replaced with countersunk versions so they look better :) Handguards do a fantastic job, really keeping the cold off. I do still knock onto the mirror stems at full lock but not enough to interfere with either the steering or the mirror adjustment.
Would definitely recommend if, like me, you really hate getting cold!
I tried to fit some on my 1200 a while back and they just kept hitting the fairing when the bars were on full lock.
Very different layout I guess? The Cheap and nasty acerbis-like ones I tried originally didn't even hit the mirror stems, I just prefer greater coverage
Hi there, are you able to show please a detailed pic of how you are securing the inside retainer of the hand guard? The fixing you used from hand guard to handlebar on the inner
there isn't one
the Storm handguard use a J shaped bracket that fixes on the bar end mount
there is an alternative that fixes the other end but still one mounting point for the bracket
there isn't one
Thank you. That was not the answer I was expecting 😊
