Hi everyone - new to this site and looking for some advice.
I am currently building a cafe racer from a basket case R45. Nothing shocking there. However, I hoped to beef up the low power output with some R65 barrels and pistons. All was going well until I fitted the upgraded barrels and pistons. It all went together well but on turning the engine over something was fouling close to tdc. When I loosened the head bolts on the left cylinder the fouling ceased.
I could not identify what is fouling, so I removed the gearbox and clutch - still fouling. I removed the alternator and cam chain cover - still fouling.
The right hand cylinder does not seem to be part of the problem.
Am I being stupid? - probably.
Is this conversion possible? Only the bores are different between the two engines although there is some difference in valve diameter and piston skirt length.
Any sensible thoughts on this issue will be most welcome although I have already considered the accidental spilling of unleaded allover the thing.
