Vincent
Hi,
Second electric probs thread... a bit all over the place at the mo...
The first one was about the "idiot lights"... can't work out what's going on. but got more issues now. I've restored the bike and fitted a new loom. This is how it is connected to the ignition switch (based on pics from other airheads and what I could work out from the wiring diagram):
This is what happen when I turn the key:
1st turn (parking): front/rear parking lights on, speedometer light on. (good so far)
2nd turn(on): no more rear/parking/speedometer lights.front light on. No break light. Full beam flick switch lights up instrument board(!?) + indicators and brakes lights when activated
3rd turn(on+lights): same as second turn + rear light on
4th turn(on+full beam): front/rear lights on, instruments board… everything working as normal….
Now, the starter motor is not rotating (refurbished Valeo from motorworks just fitted). The bike worked great for 2 days. I lent the bike to a mate for a test drive, he stalled round the corner and it would not start. Just a pronounced "click" from the starter motor.
I've changed the fuses. Battery's voltage is 12.45v. could it be something to do with the relays or a faulty ignition switch?
I will post pictures of all the electrical connections I can reach to see if anybody can spot where I could have gone wrong...
In the meantime, would anybody know what could be going on and what I should do/check?
Many thanks
Vince
Many thanks
Vince
