R80RT repaint - a tale of bikes, tools and carpentry...
MikeO
Dereham, Norfolk, today...
16th March 2012
I bought my 1983 R80RT late last year...
...knowing that it was mechanically very well sorted, but cosmetically challenged...
It had plenty of blemishes all over the bodywork...
...not all of which was the same colour.
Having got a good quote for a total respray & re-pinstripe from a local independent sprayer, Richard, I decided to strip the bodywork off the bike and let him get to work.
Richard recently painted an 1150GS Adventure tank for me...
...so I think the RT is going to be in safe hands. :cool:
So this morning I arrived at my mate Peter's place just before 08:30 to get the job done. Peter has a double garage with a bike lift and some form of electric light - none of which appears reliably in my own... :D
After a cuppa, it was time to get the bike onto the lift...
....this operation was being supervised by Jake...
Strapped down securely...
...I can't forget Greg (Deacon) telling me how he watched his 1150GS topple off his ramp... :eek
First off - the seat - everything was undoing easily, as the last owner seems to have had the entire bike apart and copper-slipped everything on reassembly... :thumb
We soon had the seat cowling off ready for the paint-shop - even managed to gently prise off the BMW badge without damaging it (although I've got new badges anyway)...
Fairing lowers next - lots of self tappers - we put all the fasteners into a big tupperware container. I'll be replacing a lot of stuff with stainless...
Headlamp trim and sidelight housing next...
We take a few pictures along the way to remind us of where each connector goes on the reassembly - the Clymer manual is great, but you can't beat a snapshot...
In no time, it seems, the majority of the fairing comes off in one piece...
...and the bike looks a little naked. We put the fairing on one side for further disassembly later...
Looks pretty good as a naked bike, I reckon...
Undo two knurled nuts and pull off two fuel lines and bingo - the tank's off...
Now we come to the slightly unconventional bit. The paintwork on the rear sub-frame is a little agricultural and, as the bike is going to be off the road for a few weeks anyway, I decided we could get the sub-frame and some other minor parts powder coated...
Of course this will leave the bike without rear suspension support. Even though it's just going into the trailer and thence directly into my garage, this is clearly going to be an issue.
Leaving the pannier frames on maintains a joint between the frame an the tops of the rear shocks, but we need to brace it...
Well, why not improvise slightly? :D
That'll do for that side...
Close enough for Government work... :augie
The bike rolls perfectly - although Peter discourages me from taking it out for a test ride... :D
We strip the lock and seat catch from the sub-frame ready to send it off to the powder coaters...
I'm sure they are going to be able to improve on the finish...
We then set to work stripping the upper fairing...
Until it's almost down to its component parts, then shove it all in the back of Peter's car and drop it into Richard's workshop. He'll take a few weeks to do the paint and I'll write up the rebuild as it happens.
Peter hitches the trailer up to his car and we drive the 25 miles back to my house and put the wooden wonder in the far end of the garage. It's 20:30 and we're both knackered...
A good day... :thumb
Nice one Mike, I'm looking forward to the rest of this thread :thumb2
[BHeadlamp trim and sidelight housing next...
The fairing wiring loom is detachable, it plugs into the main loom.
Worth remembering when it comes to re-attaching the fairing and trying to re-connect everything with it in place ;)
Thanks for that Neil :thumb2
I disconnected the multi-pin plug on the left side, but that still left the instruments etc with their wires disappearing into the loom - is there another multi-pin plug I've missed?
I had to disconnect the indictors, sidelight, instruments etc anyway, but if there's an easier way to reassemble then I'm all ears...
Mike
31st March 2012
Time to take the woodwork off...
Yesterday the weather was beautiful, so Peter and I had a 'first of the season' shakedown ride through the Lincolnshire Wolds - it was good to get the Adv back on the road after its refit...
Today's forecast wasn't as good, so I am going to refit the subframe on the RT...
As expected, Aerocoat had done a brilliant job - the subframe looks better than new...
It's all about the order you do things in, I've learned. The easiest way to fit everything is to bolt the subframe to the mudguard - that way you aren't forced to either remove the rear wheel, or get your hand in between the wheel and the mudguard to fasten the bolts...
Right - time for the wood to come off...
Then offer the subframe up. The rear mudguard has two slots in the front which have to locate onto these two pegs built into the bottom of the battery box...
I loosely bolt the subframe on...
...as I try to get everything aligned...
...then tighten everything down, finishing off by fitting these nut covers on the two upper front mounts.
Reassembling the push button & lock for the seat release was fun... :eek
But look at that grab handle - I'm really glad I went to the trouble of having these parts powder coated - I'll appreciate it every time I lift the bike onto its centre stand... :thumb
Job done - time for coffee...
Mike :cool:
Mike O.
How did you get on with the threaded inserts for the clock panel that we were talking about a few weeks ago?
Is the bike still in South Wootton, or has it moved East?
Hi Dr N,
Decided to go with Steptoe's suggestion of using black plastic number plate nuts & bolts - works a treat :thumb2
The bike's at my house (Scarning) for the rebuild - what I wouldn't have given for a bike lift today... :rolleyes:
Just about to post an electrical fault on a new thread...
Mike :D
Finished...
(Well, nearly) :D
I actually got the bodywork back on the RT back in June, after wrangling with starter motor issues, well documented elsewhere in this forum...
But it's now just about complete. It was MoT'ed last week (needed a new rear tyre), as well as having the offside cylinder head centre stud replaced. I took it out for a couple of short (50-60 mile) rides, one solo and the other with a pillion and I have to say I am very pleased with how it has turned out.
Here are some pics I took after giving it a bit of a clean and polish...
Pretty happy with the finish...
I have kept it fairly original, only replacing stuff that needed it and there was a logically better fix - stainless braided front brake hoses for example...
...and a stainless battery cage and clamp (do NOT ask what this cost :D)
I also fitted 'kidney' rocker covers, although the R80RT never came with them...
I like them - sue me... :D
I got them from Siebenrock, who have drilled them in two places to allow you to use an allen bolt to secure them to the head, rather than trying to get a nut started in between the fins...
The more observant of you (and those with OCD) will have noticed that my bike doesn't have air intakes at the front of the fairing any more...
It also has a lever near the glove box on each side of the fairing...
...which, when moved forward...
...operates these...
...which my neighbour's son has christened 'Predator' lights... :D
A rare option in the UK, I came across a set at Motorworks completely by accident. They don't, ahem, work at the moment...
But it wouldn't be a project if there wasn't at least one more thing to do, would it?
What with this current fashion for daft 'cafe racer' projects, it's great to see a real Airhead being restored to 'as good as new'...
There's going to be fewer and fewer of these bikes left, what with the passage of time, and various 'custom' projects :rolleyes:
Anyway, the bike looks great! :thumb2
Agreed. A nice sympathetic job done well. :clap
Just imagine that Sam Utting is standing over you when you clean it, "Don't forget that centre stand moynd". ;)
