R80st rear brake cam
donkeydoo
south east
Took the cam off and have checked realoem parts diagram. I am right that this extra rubber washer on the inside has no place being there cheers in advance.
Should be 4 x little o rings. Early ones only had two…. Then four, then a solid tube which connected two halves of the bevel box, negating the need for the o rings.
Made a shouldered sleeve to pull old tubes out.
Pulled new one piece tube into place.
(Hot air gun just to warm the casings nicely, and tube in the freezer for a while)
Also, shortened the level plug screw to make sure it didnot bottom out on the tube and distort it.
No problems since.
