RDC/TPMS
pitrat101
Cheshire
Looking for 2 RDC/TPMS units to fit a spare set of alloy wheels I have refurbished for my 2012 GS Twin cam, I don't mind if units are flat I have changed the batteries before. If anyone knows where to get them either second hand or new at a reasonable price would be great.
Thanks in advance
Steve
Might be worth a look below, these apparently are the same as BMW
https://www.aliexpress.com/item/603...4.0&pvid=45167c3b-5fcc-436b-b980-a95a8ee1cb03
I have had these from China, BMW name & numbers on them, they look Identical to the originals. ( probably out of the same factory) BUT They do not come with codes.
To start I used very expensive Code reader but the code on some of them came up showing letters as well as numbers, so they would not work others were fine.
I later tried the EL50448 wake up tool £6 from china and it woke the dodgy ones up wrote the codes to the Ecu and they worked fine.
So worth a go if you use the cheap wake up tool.
