Deleted account 200502001
- Joined
- Mar 10, 2014
- Messages
- 10
- Reaction score
- 3
Can anyone please confirm the torque setting for the two rear brake calliper bolts on an 09 GSA? Is it 24NM?
Do you really tighten calliper bolts with a torque wrench?
what as strange question. I can understand the self satisfied idea of being such a highly skilled mechanicDo you really tighten calliper bolts with a torque wrench?
that one can tighten bolts by feel and experience but why the hell not use a torque wrench on critical bolts like brake caliper bolts? Ok, I don't torque such bolts as those needing only 8nm, but brake, wheel, suspension and internal engine components? Hell yes, and loctite where specified. I do my mechanicing with the right tools to the right specifications - after all I'm riding the bike. Good to hear that Bear does the same.Ive attended mikeyboys workshop days, and I recall us speaking about thread lock, but I can't recall if it should be used on calliper bolts or not?
Are you saying that these bolts are not important enough to torque? Does it not matter if they come loose because you have not done them up tight enough? Are you not worried that they might shear off because you have done them up too tight?what as strange question. I can understand the self satisfied idea of being such a highly skilled mechanicthat one can tighten bolts by feel and experience but why the hell not use a torque wrench on critical bolts like brake caliper bolts? Ok, I don't torque such bolts as those needing only 8nm, but brake, wheel, suspension and internal engine components? Hell yes, and loctite where specified. I do my mechanicing with the right tools to the right specifications - after all I'm riding the bike. Good to hear that Bear does the same.
Alan R
Perhaps you should not be working on the brakes if you need a torque wrench to do up calliper bolts!
i don't need a torque wrench but I choose to use one. If you had chose to use one instead of apparently sneering at those who do, you would know that 8nm translates as hand tight on smaller diameter bolts. How many degrees passed hand tight is 24, 50, 60nm? Only a torque wrench will tell you with any degree of accuracy. Maybe you shouldn't work on brakes if you can't recognise that simple fact. There's a good little troll.Are you saying that these bolts are not important enough to torque? Does it not matter if they come loose because you have not done them up tight enough? Are you not worried that they might shear off because you have done them up too tight?
I hope the torque wrench is in better condition than your pliers![]()
