Rear brake disc and pads for r1250gs, but which?
G&T
Shropshire
Rear disc is ‘warped,’ just in tolerance but I can feel it on slow manoeuvres. It’s quite off-putting to be honest. How the hell does it go that way anyway! Started at about 8000 miles maybe.
I’m going to swap it out this Winter, but should I go BMW OEM disc and pads, I guess pads are Brembo? Or do I go down the EBC route for both? I will call BMW for codes, spec and price too.
Thanks for advice before I get going on it.
With £22 difference between EBC and Brembo Via Motorworks I would go with EBC.
As mentioned elsewhere Blue Light Discount available at EBC too.
  • Like
Reactions: G&T
I always think sportsbikeshop are good for brake pads. They will always price match too. In recent years I've always got them from there and never needed to pice match. the last time I replaced the rears on the R1250GSA I used Brembo sintered. They seemed better than the ones that were on it from new, but, it may be like tyres and always feel better with new because they get worse as they wear, and you don't notice it until you replace them. £34 isn't too bad and able to collect to save the shipping cost.
  • Like
Reactions: G&T
Personally i'd go OE
however you dont say which year GS / GSa you have
wasn't there a mix of Hayes & Brembo calipers in the 1250 era
  • Like
Reactions: G&T
OEM discs & EBC pad. Go for a sintered EBC pad, as the pedal feel is better and they last longer.
I ride a lot two up touring and use back brake loads, but have failed to warp the disc on this GS1250 with 18k on or previous which got to 32k
I would check that your floating calliper is not short of lube and dragging 8k to warp is't usual.
I run standard as they don't wear out the disc. but EBC organic should be fine
  • Like
Reactions: G&T
I’ll check on how to do that 👍
Also check the rear brake reservoir is not overfilled. It needs room for the fluid to expand when it warms up with use. There also needs to be free play in the rear brake pedal for the same reason.
  • Like
Reactions: G&T
My 1250 has been fully serviced thus far at a dealership, nevertheless I will check as you say - thanks. I have replaced the rear pedal with a GSA version, but I certainly didn’t alter the screw.
It is an odd one. First bike I’ve owned that has done this.
I remember watching a YouTube vid a while ago, where a stone got flicked up and trapped between the rear brake pedal and frame. This caused the rear brake to bind on, resulting in worn pads and warped disc.
  • Like
Reactions: G&T
