You need to be able to get to the contacts where the wiring loom connects.
If you have a test meter set it to resistance, ohms, connect to terminals and move the brake pedal (ignition off). The meter should alternate between 0 ohms (good connection, i.e. no resistance) and infinity (no connection). If the readings are variable or jump about you have a dodgy switch, assuming that you have good connection to the contacts.
If you don't have a meter get a torch battery, bulb and two bits of single core wire about 100-150mm long. Wire the bulb and battery in series and connect to switch terminals. The bulb will alternate between on and off as you work the brake pedal.
If you are close to Glasgow and want assistance PM me.
