Rear damper failure with ESA & BM warranty
zoltan
England
The damper on my 1200RT ( 05 model with 18k) started to leak oil,not at a alarming rate but the rear wheel was covered in the magic stuff. Dealer will replace the unit on Wed.
Cost : a cool £1050 plus labour. Paid by the BM extended warranty. Now some GS/GSA owners have ESA on they bike . The cost of the units vary between £750 to £850 depending of the year.
If you have extended warranty but the bike has done over 30000mile the unit is not covered.
In a bizarre way the unit can not be rebuild , dealer will keep the unit for 3 months after which he must destroy the shock. What a waste:(.
I suppose the ESA can be always replaced with a normal shock?
Just ordered a used GSA with 9k on the clock, remainder of warranty etc. I hope the ESA behaves itself.:confused:
New shock fitted , they couldn't calibrated the ESA , because the ZFE didn't recognize the new unit > Technician is waiting for a solution from BM Bracknell :augie. A replacement ZFE is around £300/400 plus labour.
Any body still waiting to have there ESA shock replaced, I've been waiting 6 weeks now and think it pretty poor:mad:
was at dealers the other day and saw my old bike still sitting there awaiting shock replacement... no fun, i know
If I read their advert right, they alter your existing shock to improve damping and replace with a Wilbers spring. Not sure if they can repair broken ones though...
Mike
i don't think so.
it's slightly ambiguous, but i'd say they use new wilbers shocks, possibly with the OEM servos to operate the ESA.
You are 100% correct Cookie. You get brand new shocks which we fit your original servos to.
Hope this helps
Pete
Mine was delivered in 48 hours, tomorrow they will fit the new ZFE .
