Hello all,
I've got a 2015 R1200GS TE with 67k miles. I went to get an oil change at BMW Maidenhead and mentioned that my ESA sometimes gets stuck in '2 helmets' preload mode, and when I cycle it back to '1 helmet', it doesn't smoothly lower to the right level. Instead after I start riding and hit a bump, there's a loud noise and the bike lowers to the correct preload level.
They mention that the ESA is failing and needs replacement at the cost of £1800. On the invoice they mention: "Rear esa dropping, check operation of esa preloadeternally, recommend replacement of rear spring str". When I asked what was wrong with it specifically they said "I don't know much about it, but it basically shouldn't drop like that", they also mentioned that soon enough I will experience a gradual loss of damping. At the moment the bike feels overdamped and any pothole or even cat's eyes make the suspension stiffen up for a split second, jolting over any bump on the road.
So, what are my options? I like having ESA and think that Dynamic ESA automatic preload adjustment is a sweet thing to have. I often ride with a pillion so electronic preload adjustment comes in very handy too.
-Is this something that the guy here that services ESA shocks can fix? Or are my shocks beyond saving at this point?
-What other options have I got? What shocks do you recommend that are compatible with ESA?
-How much do these options cost?
