Rear pad change torque please
Big-G
North Wales
Hi I'm just doing the rear pads and seem to think it's something like 24Nm caliper & 8Nm splash guard.
Anybody know better please or I'll just tighten up as I do normally.
G
Strangely enough someone made an app for the SUZUKi dr650 with all the torques and specs in it sounds like one needs making for this bike
Not sure what bolts you take out, threw the silly spray guard away a long time ago and you change the pads with your Leatherman no bolts to remove
HTH
All done and thanks.
I'm surprised no one has actually listed a set of torque settings as was the case on the last GS.
HTH
I didn't think any bolts/screws need to be removed to change the pads - pull the 'R' clips, retaining pin and push the caliper/pistons back, slide the old out and the new in - or at least that's what I did on mine?
Exactly
Well spotted
