Berwick Ranger
Evening all,
Got my lovely GS home yesterday in the foulest weather known to man. Cannot believe how filthy it was after 40 miles. Looked good though...
Anyway, I have started on a few tidying up jobs.
The rear rack (the silver coloured aluminium one) needs repainting so I started to try to take it off today. Removed the givi topbox and the black plastic latticed plate to reveal a very corroded metal plate beneath. This metal plate is connected to the rear rack with 4 allen bolts that screw in flush to the plate.
The two rearmost bolts were sized and rounded but managed to loosen with wd and heat. The two closest to the pilllion seat are completed rounded also and very seized. Tried the blowtorch and gallons of WD but nowt doing.
I took off the pillion seat and out with the tool kit to try and work out where these bolts go down to. I can't tell if there is a nut on the other end after the have gone through the rear rack on not.
I then thought that I could take off the rack with the plate still connected - then i could see underneath it all, but the rear light cluster is connected to it all!
any ideas would be MUCH appreciated.
