rear shock removal
SpanishJohn
North Hants
Hi all,
Attempting to remove the rear shock on my 2005 GS. Bottom bolt came out ok, but the top one is stuck solid. Removed the 15mm nut ok, but broke a T50 torx socket trying to spin the bolt out :(. What to do next?
Thanks in advance. SJ
Have you tried apply some heat - top bolt should just slip out.
Aplied some heat but no go. Question. Once the nut is off, should the bolt just push out, or is it threaded into the frame?
SJ
SJ
bolt should push out, have you tried tapping with a hammer? check that although the bottom bolt is out that there's no pressure pulling the shock down, sometimes the bottom of the shock is held tight.
Firstly screw the nut back on so that the nut outer face is flush with the end of the bolt. This means that when you later try to persuade the bolt out, the force will be spread down the thread and prevent distortion of the end of the thread. It also means that if the bolt decides to shoot out across the garage it will prevent the shock from dropping out.
Gently gently is the best approach as you do not want to damage bolt, frame, shock or yourself.
Stick some rags around and underneath the shock area to catch all the overspray of WD40 but be careful not to set these on fire if you decide to use an open flame method of applying heat to the bolt.
Use heat as mentioned above, preferably from a heat gun and not too close or you'll burn the paint finish.
Apply heat to the bolt and the frame and then spray with WD40 (other makes of penetrants are available :thumb), apply heat again. Repeat this 3 or four times. Apply the heat in such a way that it is not also directed at any electrical connections, plastic items or anything else likely to be damaged by heat.
With a long enough aluminium or brass drift and a hammer, try to "shock" the bolt by hitting it square on the head (if not square you could damage the bolt head). This shows it who is "boss" and might just free it enough so that when you move around to the threaded end (with nut fitted and flush with end of bolt), some gentle persuasion with the hammer and the aluminium/brass drift should get it moving. Do not hit too hard or you could start to bend or distort the bolt and/or the thread. During this give it another liberal spray with WD40 to help it on its way.
Bolt will still be hot when it is eventually freed so dont immediately grab it with bare hands. Leave the bolt, nut and shock in place till it all cools a bit.
Disclaimer:
This is how I would do it and others may not agree. It is a suggested method and I take no responsiblity for damage to property or persons involved in the removal of this bolt :augie
there will be some corrosion between bolt and ally that is holding it tight. dont bother with wd40 etc - the corrosion is corrundum ie abrasive and has very high levels of friction. instead take a couple of kettles of boiling water ( more effective and controlleable than a heat gun) and gently pour them over the ally before applying some force to the end of the bolt. But take it easy - if you cant get the bolt out you dont want to end up with a damaged and unuseable bike.
Thanks for all the replies. Tried the kettle method as sounded safer to me. Still stuck solid. Applied loads of plusgas so ill leave it for a bit now. Shame cos ive got the swingarm in bits ready for the boot replace - always something isnt there :(. If worst comes to worst ill have to put here back together and let Barhnstormers take a look at her.
SJ
