Deleted Member MS
Has anyone replaced the four 12mm bolts holding the wheel/hub, with non BM parts at all.
I just wonder what you used ??
(and can anyone confirm what tensile strength they should be ??)
Im looking to replace mine with HT S/steel but cannot find S/S with the correct HT strength for the moment.
Cheers folks
Cheers folks
The ones I've seen aren't a standard nut and bolt shape, as they were slightly tapered.
at end
