Hi Jimmy,
Wow.....It's great to see a 1200GSA with that sort of mileage and still going well, what an example.......!
With 150'000 miles on the bike I think you should be the one giving us the 'advice' on here........
Can you give some details of any of the problems you've had with your bike and what parts you've had to replace over the years and what it's like cosmetically although that's less important if you've not been riding on salty winter roads.
FP.
The first two years the bike was in the U.K. I then rode it home to Sydney.. before the warantee expired I got all the corosion fixed so that's not a problem.
Prompting the rebuild....
1. The bike's starting to burn a little more oil than normal.. 500ml per 500km or there abouts. Not ideal when I do a fair bit of long distance riding around the Australian country side.. sourcing bmw oil is a pain so I have to bring it with me. Extra weight on the dirt tracks out in the sticks makes riding less fun..
2. When the engine is cold it sometimes sounds like it's got loose bolts around inside the heads when I start it.. I've checked the clerances etc and everything seems good.. random noise scares me. Possibly related to point 1.
3. I've been plagued by random cut outs.. (see previous posts). the bike starts again perfectly fine and I can continue riding.. If the tank is lower than half way on the gauge then it's a problem above half way no cut outs... I've had several experts look at it with no success and replaced the pump.
Apart from that I've followed the service interval exactly as stated.. Some of the things I've had..
Prior to leaving the UK.
1. Heated grip failed
2. Corrosion on the front of the engine, tank, rear hub/axle.
3. All the recall/Safety notice bits.
Post UK and Various trips.
1. Random Cut outs.
2. Increased oil burning.
3. Battery Failure (at 3 years on the original)
4. Broken spokes.
5. rear shock/suspension assembly was proactively replaced as it was starting to feel scary.
6. Front end paralever bearings replaced.
7. all the regular service interval stuff.
8. the fuel pump controller things three times on the recall and to do with the cutting out which only stared once it was replaced the first time.
I've done the 20,000 km service every 15,000km's i.e. replace all the spark plugs, alternator belt, gear oil, engine oil. I did the clutch at 57,000km and again at 120,000km.
Riding Style
All my international travels have kept the speeds fairly low (generally cruising at around the 80-90km/hour range).. gives me time to react to any crazy drivers, cows, pot holes and enjoy the scenery. I wouldn't say I ride like a grandma.. but i wouldn't say I thrash the bike either. I prefer a relaxed pace. The plan is to do Africa in 2014-2015 (fingers crossed).
After being in the UK I am used to saying Miles, it's actually 150,000km as I had the speedo set to km when I left the UK.
