rechip bmw 1150's
This has become so technical that I've lost interest in making my 1150 run faster/smoother/better. Anyone else feel this ?
I was starting to feel like this, but Rogers answers to my question really helped my understanding.
Im after a device that will add a small percentage of fuel, to prevent lean running and boost throttle response (Y-Piece and Remus).
If you rechip or add a resistor type device (the most common percieved methods to correct lean running) you initially will feel a boost in responce. Over time (2 tanks/500 miles?) the Motronic will 'do its thing' with the result that any initial improvements are lost. The exception being chip responce above half throttle/6k revs could still give some enhanced performance.
The AF-XIED is a device that will give extra fuel (and therefore better throttle response) and the Motronic will not overide this. A chip could be made to work in harmony with this to fine tune everthing, which is what I think Roger would like to happen next.
The AF-XIED is fitted inline with the Lambda sensor using the existing plug/socket. It is plug and play. It has a little control box on which you can twiddle the adjustment screw, which will in turn add fuel. It will not take any fuel away so is safe at any setting. :thumb2
Many thanks Roger. Final question. I already have the y-piece and remus can installed as well as the booster plug. Filter is stock. Any recommended adjustment required on the AF-XIED or am I good to go?
It will arrive on setting 7. You should probably start on 8. Is your O2 sensor at the crux of the "Y"?
Johns chip
Don't care about all the technical stuff of what does or doesn't happen after fitting Johns chip.My bike standard 1150gs now showing 99870 miles ridden everyday,since fitting Johns stage 4 chip over 6 months ago bike has more grunt all through the gears and slightly better fuel consumption but I don't use cheap fuel, usually shell v power. Today 250 mile trip around Cotswolds 195 miles until low fuel light came on, missus on the back and not riding like a pussy. More than happy.
I'm with you on this, seat of the pants and real world riding to tell you if theres any improvment.
Yet according to whats being said here, your bike should have reverted back to how it was before you fitted the chip, but after 6 months your bike still has better grunt and mpg ?! :rolleyes:
After 6 months, a 'seat of the pants' comparison is impossible.....that human dyno tester seat of the pants ystem is only valid on a pretty much back-to back ride situation.
John was kind enough to send me a pair of chips last year....I must confess I haven't had the chance to fit and ride with them yet, but I'm really wondering if I ought to fit them now.
Like many others, I'm sort of torn between John's p.o.v and obvious knowledge of the mapping system, that of the clearly extremely learned Roger with what seems to be a wider approach to the whole set of variables that go into the running of our bikes, and the basic approach of Steptoe who is a guru as well as having a very large willy.
It's mechanics, electronics, combustion, outputs and what boils down to something that ought to be totally objective and scientific, and quantifiable in a money V power v reliability type equation, yet it's not.
It's doing my fucking head in :blast
Luke, no, I want a faster better 1150.
Roger, I apologise for being a smart arse, it's just that you keep pointing out how wrong johns method is but I have no idea how to implement your suggestions and get a faster gs. John on the other hand sells a chip that does make gs's faster.
I'm with my friend Mr Old Boots. I want a plug & play option.
Owned my bike for 12 years now and have put over 90,000 miles on it. It's used everyday so I know it pretty well, since fitting Johns chip it is definitely livelier through the gears and after 6 months still is. In my opinion it's given the old girl a new lease of life.
I ran my bike for quite a while on John’s chip and the difference was marked to the the OEM. I recently took the tank off and took the opportunity to re-fit the OEM chip to see if the difference was still so noticeable. It is.
I’ve said before that I really don’t understand all of the technical discussions and tbh I don’t care: my bike is better with John’s chip and that’s all I need to know.
R
Yep, ran my bike for six months and 2-3000 miles with Johns chip in. Without the chip in I could not keep up with my mate on his K100RS. With it in and over the six months with it in I could get in front. The bike seemed to run smoother and mpg was up. It was an 1150 GSA SE with K&N and also a stubby. John have me a stage 5. Johns chip does work and the difference is noticeable and continued to be noticeable.
As to faster, Here's a post from earlier in the thread. The stock runs on the dyno were made and then the rider gave the AF-XIEDs enough time for adaptation to occur for the runs with a richer mixture.
Here is the simple table of results from 8 passes through a dyno by an R1200GS. Tables show acceleration with two different O2 sensor settings, no chip changes.
The average rate of acceleration was 18% faster with the richer Mixutre. Link to the full results: http://www.advrider.com/forums/showthread.php?p=23512119#post23512119
I don't see you as being a smart are but my question for John is, why not connect a GS-911 and LC-2 to one of his test bikes and show us the before and after on fueling. Instead, he shows us plots of numbers from the chip. Like many of you I just want real-world, on-road numbers, not rider impressions. There was an IAT shift product in the US, that hundreds of riders exclaimed. It was later shown (and admitted) that it did not shift temperature on Hexheads or Camheads yet those riders, for years, heavily exclaimed the performance improvement. How do we explain that?
John's method on an R1150 with the O2 sensor connected doesn't make a change to fueling in the area below half throttle. He said it does, I went and installed a chip and measured it, it doesn't. But the timing changes in the chip, are permanent.
To implement lambda-shifting, which really does richen the mixture. You purchase an AF-XIED. It's plug & play, your finished.
LC-2 does the same thing but it's not plug 'n play.
Well, Ive ordered an AF-XIED so I will soon be able to report on what it does to my bike.:)
Im sure Roger mentioned that Johns chip will continue to give a boost over half throttle/6k revs. I would like a boost throughout the rev range and Rogers figures back the AF-XIED up on this.
Roger, you mentioned earlier about the location of my lambda at the crux of the y-piece. Was there a reason for this or is it just good that its mounted at a point that allows it to sample both exhaust outputs evenly?
I wish more people who have fitted the Chip would do what you have done and post their findings after a good few tanks of fuel even if it is "seat of the pants".
My main reason was that I wanted to make sure it was in a location where it measure the average of the two pipes. My second reason was to double-check that your config had an O2 sensor.
Have you ever had your injectors measured and cleaned? Balanced flow and spray pattern are important for the best results. You could try Techron Concentrate for a tank of fuel while you wait for the unit to arrive.
And yes, I have mentioned about John's chip boosting the top half of the TPS range. Sorry to be technical now but that's only true if he didn't add to much fuel in the lower half of the range. For example if he adds 4% in the closed loop area but keeps the stock O2 sensor then a long term trim is developed that removes that 4%, reducing whatever he added in the top end by that amount. If he removed fuel in the closed loop area, then an additive long term trim gets developed that would be additive to the top end. Confusing, I know. I've also said that any timing changes made in those chips are permanent.
Loads of people have Blue!
Roger's hung up on hard data to try and prove a point, it's seems most people, me included who have had one of John's chips fitted agree that even after a year the bike's performance is better in every respect.
I doubt most of us care to try and understand the figures being quoted from across the pond because we know if a motorbike feels better and becomes more economical then that's all that really matters no matter how many words try to disprove it:D
Roger.
The confuse is only by low octane petrols at US. I made new chip for low octane petrols, so will works correctly at US-Canada-Australia.
At UK and all European Union the petrols have 95 or higher octane. Does no matter if by the mod chip the AFR at close loop is richer, it is just correct, close to "1" and works much better than stock. As i said is very little richer, the lambda function works correct, that i want for the better cosnumption and for protection the cat.. After much miles there is no adapt, no back to any fantastic maps, no any confuse. Just working by the new improvement maps..
The LC tool work fine as my chip. But the results are difference. That's all. Working both. The chip gives also faster and better (variable) timing advance to the bike, it is plug & play and works like the factory stock without confusing and without conversions to other electronics of the bike.
Really thanks for talking you are a Professor :)
I will back for really exactly results at close loop, i think does no matter but i just keep on my mind.
http://ukgser.com/forums/showthread...-Tuning-Chip?p=4062557&viewfull=1#post4062557
Keep tuning :thumb2
https://www.facebook.com/JohnGS1100/media_set?set=a.360478644112438.100004509154018&type=3
https://www.facebook.com/JohnGS1100...52622731706.1073741864.100004509154018&type=3
https://www.facebook.com/JohnGS1100...23052511331.1073741843.100004509154018&type=3
https://www.facebook.com/JohnGS1100...80613808908.1073741847.100004509154018&type=3
..and this is my finally Job :
https://www.facebook.com/JohnGS1100...98603007108.1073741863.100004509154018&type=3
MORE! WE NEED MORE!!!!
I'm split on the issue Tim, there is an increasing amount of Qualitative information mounting in contradiction to Roger's extensive Quantitative data....and I'm not sure why.
You're usually in good shape after a few hundred miles but I have received reports of subtle improvements for much longer than that.
I can get the Long Term Trims for idle to converge in about a half hour, even for a shift of 15% by riding with a certain style.
So, if I'm understanding you correctly....if I fitted an aftermarket chip within a few hundred miles the closed loop adaption based on lambda setting could negate the increased fuelling of the chip within as little as a few hundred miles...
from what I understand of basic general steady state combustion...the basic principles of mixture adaption make sense...especially with the fitting of a cat....else with a bunged up filter or other factor, such as a drop in airflow/oxygen concentration would cause the engine to run too rich with unburnt fuel trashing the CAT....so it makes sense that there is a function to modify injection values in operation to allow for engines operaing in all sorts of conditions all over the world.
Taking what you say as being correct for a minute due to your extensive testing...
Is there some other 'factor' here that is confusing the issue as to why users of Johns Chip are claiming improvements over prolonged periods despite your methodical conclusions.
Do the newer chips (than you tested) have "other changes" made to say ignition timing for example that create lasting improvements that you are not measuring?
Does the act of installing the chip purge all the "learned data" over 1000's miles that is effectively "restricting the bike" and it feel's "new" again because some values have been reset to "factory fresh"?
Could there be other changes that the John's chip is making that your equipment hasn't measured, as if I've understood you correctly your only measuring the proportion of oxygen or "free air" in the exhaust - In my view, this is not the complete picture.....
There appears to me to be no measure of the proportion of CO to CO2 for that you would need the full exhaust gas analyser? I would argue, that ratio is truely a measure of combustion completeness.
If memory serves, to achieve "complete combustion" of gasoline (in simple terms) i.e. 2 C8H18 + 25 O2(g) → 16 CO2(g) + 18 H2O(g) (c/o wikipedia) you in fact need to add more oxygen than is necessary than the ideal chemical equation states is necessary.
Obviously any engine in the real world will produce some Carbon Monoxide (i.e. incomplete combusion = inefficient combustion) therefore if you reduce the amount of carbon monoxide produced you release more energy from the fuel.
So if the combustion efficiency is improved (without adding more fuel for example) and more CO is converted to CO2 then extra oxygen is taken from the free air = a drop in "free air" coming past the Lambda...that effect the lambda value even though no extra fuel was input.
I need to read my books on fuel injection to get my head around this stuff again....
Post edit..
One final point...If you add more fuel through a chip but have also reduced the restrictions in the combustion tract then more fuel and more air can still give the same AFR, however there is more fuel and more air going through the engine...more power. Whilst the chip may correct the AFR back to a default value for a an overly rich adjustment....If I'm not mistaken there is no mass or volumetric measurement of fuel and air in your evaluation...
Thus it appears to me Roger, you could be entriely correct about triming/adaption to a factory set Lambda value but have reached the wrong conclusion...however I suspect that the lambda correction does have some reducing affect on the chip but if fitted with other mods would still achieve an overall HP improvement.
