Recommend me some Winter Trail/Enduro gloves
JohnnyBoxer
North Yorkshire
I'm needing some options for winter spec gloves with the emphasis on waterproof and warmth with windproofing, without being too bulky like a road glove
Does anything exist?
I've tried Sinisalo Waterproof gloves and MSR Goretex ColdPro and have been significantly underwhelmed:tears
I put a cheap pair of Oxford muffs on, and wear normal gloves. :thumb
I've given up on finding the Holy Grail, gloves that are warm, waterproof, and you can feel the controls. :(
Mark
Mark
Good idea ! I don't think any offroad gloves are up to much as you say
Mark
Ditto
Muff on display.
Cold muffs.
And finally, Denise's. :D
Only using one press stud results in a larger opening (ooh err missus!) which I find better for movement, whilst still keeping the weather off.
HTH
Mark
Well, I've just called my local dealer and his Oxford catalogue is a little vague..... I need to check whether the product code is OF82..... Earthmover, can you assist, is this the code number your items have?
photo.php
Yes, they fit over handguards. All the bikes pictured have Cycra's on like this:
As for the Muffs shown, they look to be a little "better" than the basic ones I use. Will have a peruse of the catalogue and see if I can fnd the right ones.
Mark
photo.php
The ones I have are Oxford "Sports". They were the cheapest pair in HG at Chester, at just over £20.00. I didn't try to make them an exact fit, just held them on with a couple of cable ties to ensure I got the best comprimise between weather protection and ease of movement and control. They make a significant difference, and are cheap enough to not care about destroying them, which in two winters use I have failed to do! I even swap them on to the GS if I'm expecting foul weather. Maybe those are the new "improved" version?
Nice bike mister:augie
:blast
Mark
If you guys want Muffs, Val of this parish sells them they fit over the handguards of a 1200 (Just) I have a set in the garage somewhere if anyone wants some S/H ones, just give me time to find them.
I'd be interested in the used ones....
Picking up the oulaws from Luton airport in the evening on 28th Dec if that works?
