Mouse said:Getting the oil filter off requires some sort of special tool - do a search to see the solutions people have come up with
But apart from that, yes it's pretty simple, remove the drain plug (it's a hex key bolt), let the oil drain. Remove oil filter and replace. Replace drain plug, if you are a flash git use a new crush washer
Then refill engine with oil, the stated capacity is 3.95 l but I usually put in 3.5 l and run the engine for a short trip, then check the level on the window and top up as required. I find 3.95 l overfills my bike and the excess oil is just burnt off.
Nippy Norman does a removal tool for a tenner:
http://www.nippynormans.com/prodinfo.asp?number=OIL-1200&variation=&aitem=52&mitem=115
Regarding consumption, I've done just over 3,500 miles since the service and haven't used any oil (10W-40)....
Put in barely half a litre during the first 6,000 miles. Mixed use, lots of town (stop/blast/trickle) with a few long high speed trips.
