recovering seat
Littledumptruck
Flitwick, Beds
Hi Guys
Not long bought an 850gs, hope to keep it mainly for a winter bike.
The main flaw is the rear seat has some rips/tears on it.
Not really looking to have anything special done to it in the realms of recovering it, but does anybody know of a cover kit? Or someone that can do a simple recovering job, to something like the standard look for sensible money?
Or, does anybody have a spare unmarked rear seat in black?
Hugh
No cover kit as such.
if you want it done properly look in your yellow pages for a local car upholsterer. simple recover job shouldn't be much money. easy enough i would imagine to DIY. but getting the right stapler/adhesive/vinyl etc would make it less cost effective than having it done. by a professional.
£85!!! (you can buy a mint 2nd hand rear seat for less than that)
I was thinking in terms of maybe £25 for a simple recover jobbie.
tony archer , is yer man:thumb
or get some vinyl, staples and a hair dryer
i recoverd this seat mesen, only using one peice ov vinyl and a hair dryer to warm up and streach the cover over the foam..
IMAG0003xt600.JPG XT600 supermoto
took a while , but got a good tight finish, for about £5 :D
ugg
Me and my mate have recovered seats with this one way stretch vinyl. It really stretchy say acrossways but not the other way. Very good stuff. It was around £20 for a large A2 sheet and very easy to use. You dont need any special tools just a staple gun (few quid).
I did consider mentioning Tony Archer.. but the OP wanted a simple cost effective recover.. nothing fancy. And any car upholsterer can do that. If theres a local one then that would save a bit of cash and time with all the 'sending way' palaver. (yorkshire and back) - the postage both ways would cost more than the job itself.
I would always say 'Tony Archer' if someone wants a 'fancy job' or maybe the seat lowered/raised or repacked for comfort - that sort of jobbie.
View attachment 115108 XT600 supermoto
ugg
Looks very neat.
Did you rivet or staple the vinyl (I need to do one before much longer)?
Hi Guys
Hugh
I see you are in Flitwick, Beds
A&R Pound in Baldock will do it for you. I have a 1150GSA seat being recovered as we speak and have used them a number of times and usually charge about £20-30 for a seat recover.
Unit 27, 28, Baldock, SG7 6NG 01462 892704
They are located behind the large Tesco's in Baldock
HTH
Thanks to all that replied. A great mix of info. Had an offer of good second hand seat(thanks pete) , but think I'll check out the Baldock company first. I may even take both parts and see if they can improve the riders seat at the same time :)
Looks very neat.
staple the front , then streach each side down, be carefull not to rip the vinyl when yer pulling down, get plenty of heat to the cover.
the hard bit was the front curve , because yer vinyl wants to just pull to the back , leaving it baggy in the middle.
just perserveir and staple as ye go it will finally follow the contours of the seat..
i used a wall type staple gun, worked fine:thumb2
the vinyl stretches at least a couple of inch , but make sure ye have enough to lay right across the seat in case of cock ups , ye can always stretch it more, but not too far , it will get thinner and wrinkle easier
bet ye though i was gona give a short answer:D
another view of bike:thumb
i had to make the seat fit the rear mudguard that i cut back and modified , so the lines flowed.:cool:
the original mudguard was a crappy off the shelf part fitted on and wasnt in keeping with the supermoto looks:blast
the original seat was falling apart too, i bought my vinyl from the local market
ive still got a sheet left some wear???
take some pics of yer job , am interested to see the outcome
ugg
tony
didn't wrinklyowlie just post a whole bunch of photos about a seat that he got recovered by tony... try that there search function like :thumb
Address
Unit 7d
Bradley Mills
Bradley Mills Road
Huddersfield
HD1 6PQ
Telephone
(01484) 536 832
<!-- End CONTACT --><!-- Begin MAP -->
<MAP id=Map name=Map><AREA shape=RECT target=_blank alt="Click here for the Map" coords=5,5,259,171 href="http://maps.google.com/maps?f=q&hl=en&geocode=&q=HD1+6PQ&ie=UTF8&ll=53.656162,-1.76548&spn=0.018032,0.057335&z=15"></MAP>
Click here to see us on the map, and for directions:thumb2
<!-- End MAP -->
bloody hell sam what time do you get up! or are you an insomniac:D Anyway thanks for the contact details.
Hi Guys
Took both seat's over to Baldock yesterday afternoon. What a place, you can barely get in the door for the pile of work waiting to be done, a good old fashioned business, just like they should be :)
Estimate of £45-50 to recover both seats and rework the foam in the riders seat to allow for my damaged coccyx. Only down side is 'at least 3 weeks', but I have the Bird to ride instead, although I can see that seat going over once the GS ones are done.
Stujw90- saw your GSA seat, looks the biz. Thanks again for the info.
Hugh.
