Reflector floating around..
Bryn
Moderator
Moderator
South Leicestershire
There appears to be a bit of reflector floating around in the larger of the two units on my latest aquisition.. (1150 Adv) Its not affecting the dipped beam as far as i can see...
it doesnt look like its broken off, as from what i can see its quite uniform in shape....
The question is... can I get into it, or is it a sealed unit.... (looked like it was sealed when I took the unit out to have a look)
Had a hard night polishing in the garage.. so off to bed now.. any advice gratefully accepted....
Bryn :beerjug:
Not sealed. I successfully retrieved the side light bulb that had fallen into the main beam unit on my 1150 by wrapping some doubled sided tape onto a small stick (chop stick probably work) and fishing for it :thumb2
This is a bit probably 3-4 cm long, with two prongs on it...It won't come through the tiny hole where the bulb sits.. don't look like the frame that holds the bulb is removable...
bryn :confused:
