Hi Val,
see if this helps clarify -taken from EME Website - any probs just email John there, who is really helpful-
Price $19.00
Part #: VR-Ext/P
Replacement electronic voltage regulator with plastic housing. Nylon plastic mount absorbs vibration. Bolt-on replacement. High output regulator is pre-set at 14.3 volts which is higher than the stock voltage regulator.
Vehicle Manufacturer: BMW, Moto Guzzi
Application: 1970-1995 BMW R Airhead & Moto Guzzi 1970-1992
Make/Model: BMW, Moto Guzzi: Model 247
Model Years: 1970 to 1995
Vehicle Mfg. Part #: 12 32 1 244 409
Power Rating: 14.3 Volts
Original Equipment:
Technical Information: Plastic housing electronic voltage regulator set at 14.3 volts, which is higher than the stock unit. High output design rated up to 65 amps. Compliant nylon plastic absorbs engine's harmonic vibrations.
I have just bought one of these to fit on my PD, - will be fitting in a few days,so no direct experience as yet.
As I understand matters ...
the BMW red top regulator (standard fitting), doesn't kick-in until around 4000 Revs, and at a lower voltage,
the "police" type Black Top, kicks-in at 2000 Revs, with the higher voltage.
The "mechanical" adjustable regulator can go to a higher voltage, but can cause damage to battery if set too high ,
the EME part (as above @ $19 + p+p) , works the same as the "Police" black top, but costs a fraction of the price - no idea why MWorks are charging (pun intended !) so much for theirs.
..... again info from EME site ....
Part #: VR-Ext/Adj
Replacement electronic voltage regulator with metal housing. Bolt-on replacement. ADJUSTABLE voltage setting allows maximizing of the charging system for urban operation.
Vehicle Mfg. Part # : Not available from dealer ; replaces BMW # 12 32 1 244 409
Moto Guzzi Part # : 29703801
Power Rating: 14.3 Volts; can be adjusted to higher voltage, comes with 2- page voltage regulation adjustment guide...
Brand: EnDuraLast Brand
Technical Information: Set at 14.3 Volt trim setting; Adjustable voltage setting allow for optimizing the correct voltage for lower RPM urban operation. Must be used with caution as over charging with higher voltage setting can and will damage a battery. Metal housing electronic voltage regulator.
Not recommended to exceed 14.5 V. Misadjustment will damage electrical components, including battery !
Comes with 2-page voltage trim setting guide.
Of course you could always dispense with all the associated airhead charging problems/weaknesses by fitting the EME stator, electromagnet rotor, and do away with
original rotor, brushes, diode board, voltage regulator, and replacing with just one solid state "box", as per the following info...
# 450 Watt / 32 Amp Alternator
# Permanent Magnet Rotor, Brushless Design with remote-mounted Voltage Regulator / Rectifier !
Have this EME system on my other Turquoise PD, and it is simply brilliant- taken me on 3 long summer trips, and no probs - I can use heated grips, heated jacket, headlamps and sat nav, and not have to worry, riding slow or fast !! Would rarely have jacket and heated grips on together though. Not a cheap alternative to standard system, but waay cheaper than having a rotor or diode board pack up in the middle of nowhere !
If you need any info on all the above, check out EME's site...
http://www.euromotoelectrics.com/
Val - hope to see you ( and Jill and your dog ?) at the Wee Kend again this year,
cheers
Roger
