RickSkye
Hi
So, setting up a separate wiring loom off the battery, I can get the "ignition on" relay from the accessory socket ok, but if I want to run proper spot lights that only come on with the headlight, I would normally use a feed off the headlight full beam. I am concerned it will show a fault on the headlight or something weird on the can bus. Has any one done this successfully.
Rick
2009 r100gs
Rick
2009 r100gs
