Im hoping to drop the forks out of the top triple so that I can slide a new pair of headlight brackets on. It looks like I have to undo the pinch bolts on lower T and the large top nut in order to drop the forks.
The bike is an 1987 R80 mono with the large solid fork brace.
I read the following on Duane Ausherman's site:
"See the messed up fork retainer bolt? That is from some idiot using a Cresent wrench and letting it slip off. Don't remove that part, or you will have big troubles. It releases the fork alignment. You will have a really big job ahead of you." - http://www.w6rec.com/duane/bmw/forkseal/index.htm
Im naturally a bit concerned about this. Does anyone have any option to get the new brackets on (they must slide, they wont open enough to pop on around the fork), or any thoughts on the above quote?
Gordon
Gordon
