Removing. GSA LED spots
FD2
Liverpool England
Hi, I'm trying to take the lights off but can't work out where the tab is to release the loom connector from the light. Help? Thanks
Small Flat blade Screwdriver under the bracket at the front of the light if I remeber rightly
press down on the tab and the connector comes off
yes go in from the front of the light,there is a gap to allow a small screwdriver access
Thanks, and now done. PofP when you know. And sadly I'm keeping hold as its on PcP so they need to go back on at some point. But Clearwaters fitted now. Let there be light!
