muppix
I'm seriously considering going back to regular incandescent lamps after using HID for about 15k miles. Why? It's just not working out for me. One of the HID illuminatiors is clearly at the end of its life, it's turned milky inside and although the initial light temperature is brilliant white it warms to that of a normal bulb after a few minutes. The milkyness also seems to be affecting the dipped beam pattern to the point where it failed the MOT recently for throwing out light in the same way as high beam, though the tester thoughtfully fitted a regular bulb to get me through.
That's the first reason, the second being that one of the ballasts (this time the high beam) has developed an intermittent fault and won't stay on for more than a few milliseconds before miraculously recovering hours later. Not the kind of reliability you expect when something's supposed to last the life of the vehicle. Finally, and this is the deal-breaker, the dipped beam reflector is being burnt just above the illuminator, presumably from the heat, so I'm cutting my losses before it gets any worse.
My question is, what do I use from now onwards? The normal bulbs are OK but I'd like to squeeze as much light out of the setup as possible, so I'm thinking about PIAA or something similar. Problem is that these don't seem too reliable either if forum posts are anything to go by, with reports of MTBF between 3 and 5k miles outnumbering those from customers who are happy with their £35 lamps.
Have you downgraded from HID? What did you settle on and how long ago was it?
