- Joined
- Jan 6, 2002
- Messages
- 12,690
- Reaction score
- 1,294
Brain fade again re my 1987 R80g/s
....I want to lube the splines of the gearbox input splines to give me a smooth clutch operation.....the manual says I have to remove engine bolts to enable it to move forward in order to remove the gearbox.....is this so?
I havn't removed a gearbox for about six years now but I'm sure I didn't loosen / move the actual engine to do so !!! Hopefully I can pull the gearbox back a little so I can get some special lube onto the splines ( I think I have the correct white grease in the garage ) and save a full removal...can this be done in situ?
and could walk underneath an airhead on it's centerstand
!!! The new BWM OE cable was knackered...not when in a straight line but when in a gentle curve it was tight as a nuns crutch !!! All that work ( and a vanilla slice
