Replacement ABS Sensor front.
vRSG60
Barrowford Lancastershire
I've had new tyres fitted and must have damaged the front ABS sensor putting the wheel back on. Yes I know, I should have removed it.
ACS & ABS light permanantely on! Goes off if I mess with it but only for a short time, ABS ring looks flat when sat on the pannier to check.
If I get a replacement sensor do they need programming to the bike or can I just replace it?
