replacement Horn
Hoff
Old Submariner
Denmead, Hants
I am looking to fit a replacement horn to my F700GS as the OEM is pathetic.
I have been looking at a Denali Complete Split Sound Bomb (120dB) Horn Kit from Nippy Norman at £89.
Has anybody fitted it and if so how good is it?
Does anyone have a good quality alternative?
Paul
The Denali Soud Bomb Compact is great - the Split is tricky to fit (two components to loctate/secure) - I sent mine back.
I have the -Denali Sound Bomb Mini 113dB Horn on my 700GS & had on my 650GS b4 that..
Fits in the same place as the original horn..
https://www.nippynormans.com/horns-and-accessories/denali-sound-bomb-mini-113db-horn
Producing an massive 113 decibels of sound, the Sound Bomb is over twice as loud as a standard motorcycle horn!
The Denali Sound Bomb was designed for those who want to be heard but still want to maintain a stylish look.
Thanks to its compact design and blacked-out housing, the SoundBomb will practically disappear once installed.
At 113 decibels the distinct low-tone sound from the Denali Sound Bomb Mini is over twice as loud as a typical 100 decibel original horn.
:thumb
Thanks for the comments.
Ash, one question about the soundbomb mini. Did you just replace the OEM one or did you add a relay as well.
Looked at the reviews on Nippy and no mention of fitting a relay but saw some comments on the net about the increased amps (3 to 5) and the need for a relay.
Thoughts are if a relay is required I might as well go for the soundbomb compact.
Just added a canbus plug & away I went.
No relay needed..
I've got to ask, how often are you guys using your horns if you're willing to pay £89 to upgrade it??
I doubt I hit double figures for beeps per year of commuting...
D
Think of it as a fire extinguisher, you may not use it for years but its handy to have [especially to wake the morning commuter on his phone] :D
I have gone the soundbomb mini route which with a can bus lead was £38 with free delivery from Nippy.
Comments from Ash make it sound a wise choice. Will know when I fit it.
